Parts assist,paper sensor arm KM-8030
  • Toner Boy
    • Aug 2007
    • 366
    Need the black triangle shaped lever for paper sensing in cassette feed units (prefer to avoid purchasing assembly), part number unlisted. ???
    • 23010
    Re: Parts assist,paper sensor arm KM-8030
    Oh, that's an easy one. For future reference the CS-820 manual has a better parts breakdown, and the feed units are almost identical.
    2BC06380 Paper Empty Flag
    ... and advise your endusers not to load the trays above the upper limit line, even better about 12mm below the upper limit line. That's how those flags get broken: overfilling the trays. I once had two machines side by side in which a single enduser ... in a single day ... broke 7 out of 8 paper empty flags. =^..^=
    • Toner Boy
      • Aug 2007
      • 366
      Thanks cat, thought I may hear from you!
