FS 1135 mfp Error C6030
  • kibbs
    • Apr 2013
    • 94
    hi all.. today i am facing C6030 error... with this macine.. i changed the engine board and main board.. replace the new eprom by old one..!! update the firmware still error coming on this machine...
    thanks
    kibbs
    • 23002
    Re: FS 1135 mfp Error C6030
    Did you consider looking at the fuser? =^..^=
    • Eric1968
      • 2458
      LOL!!
      Maybe it was solved by resetting the fuser error....
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • JrTech
          • Jun 2013
          • 217
          Good afternoon. The 6000 code line refers to the Fuser unit. Have you taken it out to inspect for any damage? Below is a copy from the FS-1020 manual but the errors are same across the FS models.
          2FM
          1-5-8
          Code Error indications Contents
          Check procedures/corrective measures
          Yes
          Yes
          Yes
          No
          No
          Turn power switch off,
          and remove power
          cable.
          Detach connector CN4
          on power supply board.
          Detach connector CN1
          Measure resistance
          between pins 1 and 2
          of the detached
          connector.
          Replace fuser thermistor.
          See page 1-6-25.
          Replace thermal cutout or
          heater lamp. See page 1-6-
          26 or 1-6-22.
          Replace bias board or high
          voltage board or power
          supply board. See page 1-6-
          13 or 1-6-12.
          Open (infinite)?
          No
          No
          Open (infinite)?
          Measure resistance
          between pins 1 and 3
          of the detached
          connector.
          Replace harness
          (2FM2601) between
          engine board (KP-1046)
          and bias board (KP-
          1051).
          End.
