3050ci Cassette Error when Receiving Faxes
  • cbs
    • Apr 2011
    • 86
    We have a customer that gets an error/notice to load paper in Cassette 1 (Letter, Plain) when receiving faxes. The tray is full with letter paper and the tray is set to letter/plain (we've tried Auto as well). Printing and copying work fine; it's only ocurring when they are receiving faxes. Latest firmware applied.
    • 23009
    Re: 3050ci Cassette Error when Receiving Faxes
    You say you've tried the Auto setting. I think that will solve your problem. The fax can only auto select trays set to Auto Detect, not hard set to a specific size. Try it again. =^..^=
    • copymech
      • Sep 2011
      • 196
      In auto paper screen you can select inch or ab sizes. Also check if auto reduce is on. It will reduce legal sizes to letter. If sender has a problem with there scanner it may send a letter as legal ect.
      • cbs
        • Apr 2011
        • 86
        set the FAX > Basic > to All Media Types. That seems to have it working for now. Strange, even though Plain was set here and the Cassette 1 was set to plain that the MFP didn't like it.
