Kyocera 3035 Error"Open cassette 1, Check and Remove Paper From inside of Machine"
  • kibbs
    • Apr 2013
    • 94
    hi all,
    Today i was facing a problem in a customer place. Kyocera 3035 Error Message on Cassette 1" Open cassette 1, Check and Remove Paper From inside of Machine" by swap lift motor it is not working.. it detects paper size A3, A4 Pro and orientation...!! Cassette Push button also working..
    And also i swap cassette and Cassette Paper feed section..however 2 cassette working fine after swaping also...!!!
    Please fix my problem Guys..!!
    • 23010
    Re: Kyocera 3035 Error"Open cassette 1, Check and Remove Paper From inside of Machine
    Is there, maybe, a C1010 error stored on the machine that might isolate tray #1?
    You might try clearing the error with a partial reset U906? =^..^=
    • kibbs
      • Apr 2013
      • 94
      iTs their in a service call report..!! i resetted twice a time then also their is no change in that machine..!!
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
          • 23010
          It's not uncommon to have a shorting lift motor damage the motor driver circuit(s) on the engine PWB. If you swap the shorting motor to the other paper port it can damage the motor driver circuits for both paper drawers. The only sure way to get past this circular sequence of events is to:
          1) Replace both lift motors and engine PWB simultaneously.
          2) Perform U906 partial reset.
