command center for 3050
  • T911
    • Jun 2007
    • 628
    I tried all user and passwords to get in but no luck. Admin. Admin00. admin admin. Can't get in. Can I reset the command center to defauld through service mode. Memory clear 021 i think may do it but it will effect other stuff. Thx
    • 23010
    Re: command center for 3050
    The default is "no password".
    Easiest solution: Ask the guy who set it.
    Second easiest solution: U021, then resetting your destination, addressbook, network settings, screen defaults, any FRPO changes ... but you knew that. =^..^=
    • madas
      • Aug 2008
      • 313
      Is this the KM or TA?
      On the TA try going into sys/menu-job acct-user login-user list
      it shows you the login details for m/c and command centre, this is avsailable on most if not all the later m/c's including smart m/c's
      Madas
