fuser nip
  • hachetman
    • Jul 2009
    • 96
    [Misc] fuser nip
    I am new to this line I have an 820 that is not fusing ink to the paper I was wondering wat the procure and the spec for setting the fuser nip
    Thankz
    Steve baker
    Steve Baker
    hachet1_12@outlook.com
    • 23010
    Re: fuser nip
    There are just two really beefy springs, no adjustments.
    The most common causes for poor fusing are:
    1) Worn or damaged pressure roller.
    2) Worn or damaged heat roller bearings or pressure roller bearings.
    3) Incorrect media type set, especially with heavy paper stock.
    4) Incorrect fuser temperature set (see your service mode as to what the default is).
    How many clicks on this fuser? Expect rebuild at 500K.
    What media type is being used and fed from what tray?
    Has a tech changed the fuser temperature setting? Standard setting work fine.
    • JustManuals
      • Jan 2006
      • 9838
      Re: fuser nip
      Paul@justmanuals.com
