FSC8025 scanning issue
  • daveyball
    • May 2009
    • 314
    I have an issue with FSC8025, which seems to be duplicating the scans. The SMB path is \\server\scans\username. It's putting the image in the user name folder, but also a copy in the scans folder. Have recreated the address, upgraded the firmware, still the same.
    Any Ideas?
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: FSC8025 scanning issue
    I suppose you could install SFU and scan as FTP as a workaround.
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • daveyball
      • May 2009
      • 314
      I set up to scan to a local machine on the same network, and it's OK, but not on the server. This is weird
        • 23008
        I don't know how pertinent this is, but if you have 10 sub-folders named "scans" each within separate differently named folders, you'll get a copy of the scan in each and every "scans" folder. I discovered it at a lawyers office who wanted this elaborate folder structure for each client. If the sub-folder structure was the same, we ended up with many multiple copies of the scan. The spur of the moment solution was to slightly alter each sub-folder structure. For example: Addressbook entry #1 went to \\server\Share\ABC Manufacturing\Lawsuits\scan1. =^..^=
        • daveyball
          • May 2009
          • 314
          re created the address book, after backing it up failed. That sorted it. But found the account used locked. Anyway when that was sorted it worked fine. Not sure what the issue really was in the end. Thanks for any advise
