Kyocera Copy star CS 305 Black copies prints are fine
  • Jude
    • Oct 2009
    • 256
    I did a cleaning of this machine and a day later the copies turned black. Prints and internal reports are fine. Checked optics and connections. Lamp does come on. Mirrors are in position ok. HAs anyone seen this?
  • copymech
    • Sep 2011
    • 196
    Re: Kyocera Copy star CS 305 Black copies prints are fine
    Reset the scanner lock. It will prevent the scanner from going to the scanner start position with no errors.
    • Jude
      • Oct 2009
      • 256
      Thanks brother! Will check and see.
      • Jude
        • Oct 2009
        • 256
        Just had the client check the position of the scanner lock and it was unlocked . I had them lock then unlock then reset the machine and still same thing. Not sure what else? This is a real puzzler.
        • Jules Winfield
          • Jul 2009
          • 821
          It sounds like a dust ball or something worked it's way into the light path. I would try re-cleaning the optics...
          But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
          • kkendric
            • 301
            There is a bulletin regarding this exact issue, requires replacing the main board from Kyocera if under warranty. Thtere are repair centers thar also repair this problem as well. A transistor array that controls the CIS on/off signal fries and needs to be replaced.
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
                • 23009
                Unfortunately kkendric is correct. You may also get errors C3200. Replace main PWB. Error C0180 appears on power up (serial number mismatch). Run sim U004 to restore serial number on main PWB. Re-enter network and addressbook data.
                When you move the machine around, make sure you don't lock the scanner. It's easy to do. =^..^=
