Kyocera Taskalfa 3550ci Color issue..
  • kibbs
    • Apr 2013
    • 94
    Dear Friends,
    Today i got a call from an customer regarding the color issue both copying and printing.. then i upgrade the latest firmware and calibiration and half tone adjust then also the problem seems same.. i opened the machine then i serviced machine Drum, charger, developer seems okay.. with this post i attached the status page and maintanence report for your view...
    Thanks & Regards
    kibbsdoc00789620131126162432.pdf
  • tech.gasm
    • Sep 2010
    • 39
    Re: Kyocera Taskalfa 3550ci Color issue..
    Originally posted by kibbs
    Dear Friends,
    Thanks & Regards
    kibbs[ATTACH]23065[/ATTACH]
    How about skyshots..how do they appear?
    Is color also affected or b/w only?
    • kibbs
      • Apr 2013
      • 94
      you can see the status report i attach that also..!! in black and white copy also it appearing..!! only 60000 copies only made by the machine.. how don't knw how they appear.. searching for the solution..
      • luis8832
        • Dec 2008
        • 250
        On the kyocera website there is a troubleshooting guide for these units. There are several reasons why you would get that affect on your copies and prints.
        Download it and check out the first section. Let me know if it helps. Forget downloading, here it is. Good luck!
        • kibbs
          • Apr 2013
          • 94
          Hey thanks a lot for your guide man..!! you save my time.. i try with the first section.. adjusting the value and calibration and everthing in the first section with the one by one procedure.. still problem looks same.. my head rouding i dono how it happens and still searching solutions in internet..
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            Did you stop a print half way to see if image is on transfer belt but not transferring? Is the transfer roller sitting properly with spring tension on front and rear? Maybe missing a spring?
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • luis8832
              • Dec 2008
              • 250
              Did you try cleaning the charge rollers?
              • kibbs
                • Apr 2013
                • 94
                I am the first person open the machine first time.. it was their in our record it is one year old machine machine.. i think warranty finished last month. from the date of installation..
                • kibbs
                  • Apr 2013
                  • 94
                  yes i cleaned with cotton wet cloth and wipe with dry cotton cloth..
                  • taskalfaman
                    • Nov 2009
                    • 137
                    this is clearly a transfer issue.
                    plse check transfer roller/Belt, => it seems to be a comman part.
                    please print out a color belt (A3) and scan the printed page.
                    • kibbs
                      • Apr 2013
                      • 94
                      yes.. i ll check with the transfer belt..!! transfer roller i checked it still in black color no scratch in that.. i did the 089 a3 print out in that also same..!!
                      • Venom
                        • Nov 2009
                        • 765
                        Do I really care who the first person to open the machine up was? Do I really care if warranty finished last month? I asked if you checked transfer roller....WTF
                          • 22999
                          Sorry for the slow response. I just saw you're attachments today.
                          I'll have to agree with both these gentlemen. It's clearly a transfer issue, but not so clearly whether it's primary transfer or secondary transfer. Are you getting some unaccountable gear noise? I had one recently that the secondary transfer shift gear pack cracked, and the secondary transfer unit would sometimes move properly, most times not and errored out.
                          Like venom says, the thing to do is emergency stop the machine with a ledger or A3 image, and see exactly where your image degrades. =^..^=
                          • kibbs
                            • Apr 2013
                            • 94
                            Today i find the problem and fix the problem with the help of you guys... The problem is from the Transfer roller side. In the side door section already the door little damaged thats why it cause this problem.. I removed the door i cut the damaged part and checked.. then after i am get the perfect copy..!!
                            Thanks & regards
                            kibbs
                              • 22999
                              Just for curiosity sake, what damaged part? If you cannot describe it take a photo. =^..^=
