3550ci image problem
  • oldtech1
    • Mar 2008
    • 35
    [Misc] 3550ci image problem
    can anyone suggest adjustment? I already replaced drum. see attachment
  • Larhal
    Semi Retired
    • 532
    Re: 3550ci image problem
    Looks like DLV sleeve roller pitch.
    As per KM:
    Upgrade firmware.
    Execute Dev refresh
    Replace colour DLP unit which is causing the problem.
    Larhal
    Larhal
    Retired Part Time
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • kibbs
      • Apr 2013
      • 94
      1.Refresh dev...
      2.check the main charge..
      3.transfer roller
      • Eric1968
        • 2458
        This image defect is mentioned in the Troubleshooting Guide. replace the DV-Unit.
        • oldtech1
          • Mar 2008
          • 35
          thanks, the developer is backordered till the 21st
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
              • 22927
              If you were to print the U089 gray test pattern you could see the interval ... and yes it looks like developing. =^..^=
              • oldtech1
                • Mar 2008
                • 35
                Thanks The item is backorderd tiil the 21st.
                • Larhal
                  Semi Retired
                  • 532
                  Just for your information,
                  I had the same issue and dev's were not readily available. I found that if you take some developer from and older unit and put it in the weak unit it revives and stops all this from happening.
                  I know that the Kyocera toner has developer in it to replace lost developer in the units. Seems that sometimes they use more than projected so the CQ gets light and patchy.
                  I wonder if we can just get some developer , don't know from where , to top off these units instead of having to replace the whole unit?
                  Any thoughts?
                  Larhal
                  Larhal
                  Retired Part Time
