Kyocera FS-C2626MFP : won't print black
  • RandyW
    • Jan 2013
    • 213
    someone called us up with a FS-C2626MFP that won't print black. I believe this was going on and then they tried changing the toner and it didn't help. I believe the other colors are ok.
    we haven't looked at it yet. I saw something about a gear breaking on another thread that would effect print quality (might have been a different Kyocera C2126 maybe).
  • JustManuals
    • Jan 2006
    • 9838
    Re: Kyocera FS-C2626MFP : won't print black
    Paul@justmanuals.com
    • Eric1968
      • 2458
      Could be a bad connection of the Development Unit or Drum Unit. Try reseating them.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1878
        Send someone else on the call, then don't answer the phone........
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
          • 23006
          If I was you I'd search for one of the dozens of posts about the Gemini updates, like this one:
          http://www.copytechnet.com/forums/ar...p/t-81342.html
          • RandyW
            • Jan 2013
            • 213
            lol.
            probably reseating the toner did the trick...they called back a little later saying the guy they got the toner from took care of it. I assume that means they were using some sort of refills or something.
