KM-3050 - Intermittent error C3310 and adjusting Scanner
  • aborad
    • Aug 2011
    • 61
    Hi,
    In KM-3050 intermittent error code C3310 showing. as per manuals its related to CIS AGC Problem. we have replaced DP Main PWB. but problem still there.
    also we have replaced DP inverter PWB. But Problem not resolved. please help to resolve this issue.
    • 23009
    Re: KM-3050 - Intermittent error C3310 and adjusting Scanner
    First check the connector for the CIS on the back cover of the machine. Check for bent pins or bad connections, it's very common. Check continuity from the engine PWB to the DP controller.
    Next the CIS Assy inside the DP. =^..^=
    Edit: for the "Adjusting Scanner" message check that the top DP door is closed:
    "Adjusting Scanner" message, whenever originals are placed in the DP-700 document processor and Start pressed. Message does not clear. Top cover of document processor has been forceably opened, damaging the rear hook and interlock switch holder. Replace rear hook (303JX07180) and interlock switch holder (303JX02240).
    • darry1322
      • Oct 2010
      • 817
      I've replaced a few scanner control pwb's for the adjusting scanner issue. It's the board the larger adf cable plugs into.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • aborad
          • Aug 2011
          • 61
          Thanks for your reply ,I will check and update the status...
