km-1650
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5019
    km-1650
    Hello
    I'm not kyocera guy so i need a advice.I have all manuals for this model but i'm still not sure about it.Command center is password locked and company have new IT guy.I already try default password.
    Canon have function for reset pass in service mode.Do we have something similar here?
    Thanks in advance.
  • zeeeba
    • Dec 2012
    • 58
    Re: km-1650
    If, You have service manual execute : "Initialize all memory" in service mode. Now I'm not remember what is exacty it is i This U020, U021 or U022 one of these is that procedure, but be carefull : if Your machine has ADF, after this procedure You must do adjustments for lead edge for scan/copy.
      • 23010
      Re: km-1650
      The default is: no authentication at all
      The memory clear, or engine reset PreScribe command are about the only way to reset that password. If you do the memory clear, don't forget to reset the destination (U252 or maybe U265) which is the badge: Kyocera, Copystar, Utax, Olivetti, etc. (Copystar: 66, Kyocera Mita: 2, Utax: 11, Olivetti: 12)
      • zoraldinho
        • Mar 2008
        • 5019
        Re: km-1650
        Me again
        One more stupid question! I use U020 Initializing all data and U021 Initializing memories.Scanner admin pass is still there.I'm gona throw this peace of s..
        • zeeeba
          • Dec 2012
          • 58
          Re: km-1650
          When you initialize U020 or U021 The password was not deleted but it is resseted to default. If I remember the default password is 1600 or 2500
