DF - 710 Not stable and Giving Jam 88
  • kibbs
    • Apr 2013
    • 94
    Dear Friends,
    Today i worked on the DF-710(KM-3050).. Punching okay for me.. While stable time it is not stabling.. i change the Stable unit also Part no: ( 303JY44010- Stapler EH590). then also stable not working and finisher giving Jam 88..This is the First time i working on this finisher.. Please need some help.
    Regrads
    Kibbs
  • Piratex
    Re: DF - 710 Not stable and Giving Jam 88
    Hello,
    could you in the end solve the problem with your finisher giving jam 88??
    Originally posted by kibbs
    Dear Friends,
    Regrads
    Kibbs
      • 23009
      Does this help?:
      Misfeeds (Jam J88) paper is folded over while exiting the holding tray of the DF-710. Finished paper shows notable upward curl in the tray. Poor quality paper. Compensation can be made by adjusting de-curl rollers E1 & E2 (default is 1). For downward curl increase E1, & default E2. For upward curl increase E2, & default E1.
      • Piratex
        where are the-curl rollers E1 & E2??
        Does this help?:
          • 23009
          This is one of those situations where a professional technician would open their service manual and read about the function of rollers E1 and E2. You too, can act like a professional technician, even if you aren't one.
          Don't have a manual? See Paul for the DF-710 Service Manual at www.just manuals.com
          • jmaister
            certified scrub
            • Aug 2010
            • 755
            Please check bulletin #A387-3LT-0007 in KDAconnect Helpdesk Knowledgebase, regarding timing procedure. Its for DF760, but they are the same essentially.
            Idling colour developers are not healthy developers.
