400ci detached finisher
  • micko_gm
    • May 2008
    • 18
    Good Day,
    In regards with kyocera mita TASKalfa 400ci,i need to know the procedure of enabling the finisher,or it is enable automatically when connected to machine...
    thank you :-)
  • kkendric
    • 301
    Re: 400ci detached finisher
    If you connect it and it is not recognized you need to go into the service mode and execute a simulation 906, reset disable function.
      • 22997
      All Kyocera options are plug & play. If the option is not recognized the most common problems are connectors or the accessory is isolated due to an error. U906 should clear an error. =^..^=
      • micko_gm
        • May 2008
        • 18
        thanks guys,i will give you feedback if it's resolve..
        • micko_gm
          • May 2008
          • 18
          its done,working fine...thanks a lot.
