KM-2050
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5000
    KM-2050
    Hi
    I'm Canon tech and i'm not familiar with this brand so i need advice from Kyo. guru. Document feeder won't detect originals any more.I already inspect regular issues.Before i start changing sensors is it possible by any chance turn off auto feeder with keyboard?
    Thanks.
  • kkendric
    • 301
    Re: KM-2050
    This series had/has error problems with the document processor. In the past they would error out, (C0410), communication error with Doc pricessor and main board. there were several bulletins and fixes including replacing processor board. All reepairs delt with grounding issues. First get into service mode and do a 906 to reset any devices that may have been disabled due to errors. If that restores operation you should be ok until a large static charge strikes again. This problem occurs mostly in the winter, heated offices, no humidity, 30% or less someone walking accross a carpet building up a static charge placed documents in feeder, zap loss of data from Feeder to main board, hope this helps.
    • zoraldinho
      • Mar 2008
      • 5000
      Re: KM-2050
      Thanks a lot. I got part catalog without feeder parts!? Have Kyocera separated parts manual for feeder?? Need part number for processor board.Thanks again kkendric.
        • 22935
        Re: KM-2050
        My manual has all the accessories:
        303HL01032 Main PCB DP-410
        • zoraldinho
          • Mar 2008
          • 5000
          Re: KM-2050
          Your manual is awesome!
          Thanks for part number.
          • JITHU
            • Apr 2013
            • 3
            Re: KM-2050
            Replace Feeder interface cable.
            • MR Bill
              • 532
              Re: KM-2050
              Yes, replace the harness first. Lifting the feeder up and down or pushing the machine up tight against the wall will sometimes break a wire. Harness part # is 3HK27020
              • zoraldinho
                • Mar 2008
                • 5000
                Re: KM-2050
                This is good info.Thanks a lot guys.I appreciate that.
                • JR2ALTA
                  • Feb 2010
                  • 2028
                  Don't replace harness for c0410. That is definitely the board which was updated for this code.
                  • zoraldinho
                    • Mar 2008
                    • 5000
                    Re: KM-2050
                    Feeder interface cable was bad.Thanks for help again.
