TaskAlfa 5500i C0980
  • habik
    • 2013
    Hello There,
    Have a machine that came with
    C0980 - 24 V power down detect24V disconnection signal is
    detected for 1 s and 12V
    disconnection signal is not
    detected.
    So I though PWR supply or something shorting.
    Went to clients machine, changed power supply and it was giving 24v although only up to the FWPB1.
    Then I came across a bulletin with this code. So I have checked for any pinched wires for fans. None found checked continuity on wiring. All clear. Except fuse one Fuse on FPWB1 which is now open. So changed the fan and FPWB1 as per bulletin when we pulled the machine to workshop. Hoping for machine to boot and again C0980.
    Going now to strip it and check for any other wires to be pinched which will be a pain. Just thought if any of you had similar issue and it wasn't a pinched wire on Cooling fan DLP70 as per KM bulletin.
    Cheers for any suggestions.
    Firmwares HERE
  • habik
    • 2013
    Re: TaskAlfa 5500i C0980
    I would strongly advise to check on next visit for any 5500i or such, and see if you have a connector TN_FAN2 on YC19 harness for EPWB somehow close to the mainframe of the machine. Mine was touching with pins a screw just above it and grounding 24V right through the mainframe. I would suggest to wrappit with isolation tape!!
    Firmwares HERE
      • 22999
      What an amazing find habik! That appears to be a dead ended connector (maybe for some component that never made it to this model), that just happens to be resting on screw threads. And replacing the fuse restored power? Congratulations! =^..^=
      • habik
        • 2013
        Ordered T7A 125V fuses... so We shall see
        Firmwares HERE
        • habik
          • 2013
          Boards FPWB1 re-fused and working. Have a nice weekend.
          Firmwares HERE
            • 22999
            Congratulations habik! =^..^=
            • Alexkyocera
              • Jul 2015
              • 82
              Do you think that this is the same for the TASKalfa 3051ci??
              What Board was refused?
                • 22999
                • subaro
                  • Oct 2010
                  • 1274
                  refused = indicate or show that one is not willing to do something.
                  re-fused = could it mean replacing the blown fuse..
                  habik
                  The guy has a point, he is confused.
                  • Alexkyocera
                    • Jul 2015
                    • 82
                    [QUOTE=subaro;518246]Do you think that this is the same for the TASKalfa 3051ci??
                    Thanks Subaro.. I replaced the Low village Board and the problem was resolved on the TASKALFA 3051ci.
                    habik
                    [/QUOTE
                    Thanks Subaro but I replaced the Low voltage board at the customer office today and the machine is now working okay.
                    • subaro
                      • Oct 2010
                      • 1274
                      [QUOTE=Alexkyocera;518257]
                      habik
                      [/QUOTE
                      Great, your problem is solved. Stay with CTN and don't be afraid to ask the questions. The terminologies will make sense as you go along. cheers.
