Kyocera KM-2050
  • MR Bill
    • 532
    Kyocera KM-2050
    Have a KM-2050 that when you do a 2 sided duplex copy it will make some streaks on the back side. I know there is some kind of a bullitin about this and a mylar mod to put in the switchback assy?? Not sure but can someone fill me in on this. Part # and instructions would be great.Thank you for any infomation.Mr Bill
    • 22999
    Re: Kyocera KM-2050
    I'm not aware of a bulletin. The thing I'd examine is the transfer roller bushings and pressure springs. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      Re: Kyocera KM-2050
      Mr BILL - If you want the Parts & Service manual on this, just shoot me an email to paul@justmanuals.com and I'll send it along at no charge.
      Paul@justmanuals.com
      • MR Bill
        • 532
        Re: Kyocera KM-2050
        Thanks a lot for the offer Paul. I have it already tho. Just looking for this mod , if the is one. Thanks again.
        • Ingersoll
          • Nov 2008
          • 74
          Re: Kyocera KM-2050
          I saw a similiar problem with CS-5035 series, fixed it with a firmware update, had to do with increasing voltage on the transfer roller during duplex. Might be worth a try. If you read the docs on the firmware update it says what it fixes.
          • MR Bill
            • 532
            Re: Kyocera KM-2050
            Thanks for all replys.I found the bullitin and mod to fix the problem. It has something to due with condensation . Kyocera bulletin # 2C9-0061 . Not sure if i will see the problem again. It happens when the machine is in a cold enviroment and gets turned on and then you get damp paper going throught the fuser and then streaks when paper backs up on duplexing. I installed this machine in a warm enviroment so I think I'm good. But I have the bulletin to fix if problem comes back. Thanks.
              • 22999
              Re: Kyocera KM-2050
              I definitely prefer the warmer environment whenever possible. =^..^=
