Kyocera TaskAlfa 4501i Error Code
  • RoyROd
    • Mar 2013
    • 29
    [Error Code] Kyocera TaskAlfa 4501i Error Code
    I've got a week old TaskAlfa 4501i that was giving me intervals of C0640 and F357 error codes. After speaking with Kyocera tech support they told me to upgrade firmware, reseat memory DIMMs and reseat the HDD. After doing all these, to no avail, they finally told to run a U024 which initializes the HDD. After doing so the machine came back up with an F345 code. Tech support has had me redo firmware, try individually install firmware, all to no avail. Has anyone seen something like this and if so do they have any advice?
  • kkendric
    • 301
    Re: Kyocera TaskAlfa 4501i Error Code
    You could try changing the Hard drive data cable(SATA) and if that does not work replace the Hard drive.
      • 23009
      I'd have changed the HDD by now.
      C0640: HDD failure
      CF35x: An error is detected at the Print control section. 1) Reformat HDD U024 FULL; 2) Initialize backup memory U021; 3) Repl main PWB; 4) Repl HDD;
      CF34x: An error is detected at the Panel management section. 1) Reseat connectors: main PWB-YC12, YC17, YC30; Op Panel-YC1 YC2, YC3; 2) Reformat HDD U024 FULL; 3) Initialize backup memory U021; 4) Repl Op panel PWB; 5) Repl main PWB;
      • Enscoe09
        Hello,
        Was there any resolution to this F345 error code? Experiencing "F345" error code on the 3252ci Kyocera. Customer was getting a white screen in the morning. updated firmware and then started getting F345 error code in the morning. The customer has to shut the device down and turn it back on and it will work ok.(there were a lot of other weird things going on such as power inconsistencies and paper jams about 3 other error codes, but these were resolved either from what we tried below or by switching the power to a new outlet. This device is in a large commercial building with high security and for whatever reason it is hard to find the electrical schematics. customer was also pulling the plug of the machine to fresolve the white screen in the morning rather than using the rocker switch which COULD have caused more problems as well) At some point through the evening, the machine gets the F345 error code while it is sitting overnight.
        Tried to reload the firmware. reformatted hard drive (while reformatting hard drive could not complete backup because the files pulled from hard drive were corrupt. Had to manually re-configure unit for client. Reseated DIMMS and connector units. Replaced the main PWB. Still receiving F345 error every morning.
        Per Kyocera tech support, the F345 error code is not in the service manual. Hard to believe that Kyocera tech support has not heard of this code? I am trying to do my due diligence versus just throwing parts at the machine.
        Thank you kindly,
        Ashley
        • sparkycivic
          • Apr 2017
          • 348
          Hi,
          Per the service manual: Where X is any number or letter...
          F34X Abnormality detecting in the Panel Management
          Department
          1. Check the harness between Panel<=>Main boards, and the
          connection state of a connector, and perform an operation
          check.
          * Notes
          2. Initialize HDD and perform an operation check.
          (FULL of U024) *
          3. U021 Controller backup initialization is carried out and an operation
          check is performed.
          4. Exchange a Panel board and perform an operation check.
          * Notes
          5. Exchange a Main board and perform an operation check.
          6. Get USBLOG and contact service headquarters.
          * Only HDD standard model
          * Note : A Dual Core CPU model and HyPAS model
          Is a cable pinched or FFC cable conductor peeled-back inside connector?
          • mman
            • Feb 2015
            • 1
            Replace the HDD
            • jmaister
              certified scrub
              • Aug 2010
              • 755
              why is this so much like the iR ADV 2nd gen?
              1. error code corresponding to HDD, change the HDD
              2. screen freezing on start up, change the HDD
              atleast Kyocera HDD is your normal mobile HDD.
              Idling colour developers are not healthy developers.
