Kyocera KM - 4035
  • jeromeblanks
    • Jul 2010
    • 13
    [CQ] Kyocera KM - 4035
    I have a KM-C4035 internal prints are fine and off the glass is fine but when I use the ADF I get intermittent CQ sometimes pages are blank sometimes heavy background and sometimes washed out copies never a clear copy any suggestions
    • 23008
    Re: Kyocera KM - 4035
    Ok Jerome. There is no model KM-C4035. If it's in the Voyager or VoyagerE series it's got to be either:
    KM-C2520, KM-C3225, KM-C3232, KM-C2525E, KM-C3225E, KM-C3232E, or a KM-C4035E
    If its a Falcon II series it could be a:
    KM-3035, KM-4035, or KM-5035
    Lets start by choosing a valid model, then proceed from there. =^..^=
    • eliza925994
      • Jun 2014
      • 14
      Kyocera KM - 4035 - please use this.
      Max. original size:A3
      Continuous copying:1-999
      Memory capacity:Standard 64 MB, max. 64 MB + 20 GB HDD (with HD-70)
      Zoom range:25-400% in 1% steps (with DP: 25-200%)
      Preset magnification ratios:21R / 9E
      • eliza925994
        • Jun 2014
        • 14
        check your printing setting and then print. or uninstall the printer then install the printer again then printer has default setting and print the paper. sometimes printer current pages print which is selected by setting.you must select all the pages. to change the setting. and open control panel then open printers and faxes then check setting.
        Kyocera Copiers in Brisbane
