HUES & I don't mean Howard
  • blackdog
    • Jun 2012
    • 211
    Hey got a TA250ci with tooo much yellow hues.
    i.e.; beige is yellow.
    Anyone have the best solution to adjust other than spending several hours with a few dozen adjustments.
    Thanks, it's me.
  • Zackuth
    • Aug 2009
    • 448
    Re: HUES & I don't mean Howard
    You can try and replace the dev unit. Other than that, it's adjustment time.
    If at first you don't succeed, redefine success
    • blackdog
      • Jun 2012
      • 211
      "Da BEARS" thanks. Looks like breakfast, lunch & supper at account.
        • 23010
        Nope. Clean the primarys, optics, and full calibration. Then take a look at the U089 gray test prints. That's the row to hoe. =^..^=
        • tmaged
          Owner/Service Manager
          • 1890
          Blackcat is correct. Print off your color bands in 089. My guess is there's a problem with one of the other colors that is throwing the calibration off.
          The machine doesn't see what it needs, so it tries to compensate. Checking what the gray looks like makes all the difference.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • blackdog
            • Jun 2012
            • 211
            Last two posts thanks for your input this should save me some time.
            This box has 450k on it and I have no idea if a PM kit has been completed.
            • blackdog
              • Jun 2012
              • 211
              Hey Blackcat I wanted to update you on the TA520i MP Tray issue I was at a standstill with.
              The LCT did have failed lift motors, as you suggested but no matter what we tried to do to correct the "install paper in MP Tray error" and locking the unit up I was a dead-end street.
              Finally I stumbled across a user adjustment called Tray For Cover. WTF was this I said to myself?
              Turns out when a fax is coming in, the cover is assigned to MP Tray even though printer and fax was assigned to Tray 1.
              Kyocera mean's to tell me the machine is suppose to distinguish a cover sheet. Wow, I have a cool bridge for sale too.
              Anyway once I set cover to tray 1 all was fine in Munchkin Land.
              Never in my life have I run across this type of app on any other box.
              And to boot every box with fax option that I have run across since has this app as a default.
                • 23010
                It's probably 1/2 way into it's second PM cycle. If it's low color volume though, the MK-865B kit may never have been installed (300K color). =^..^=
                • blackdog
                  • Jun 2012
                  • 211
                  Blackcat you are Uno #1 in my book! I can always count on you for solid advice.
                  The stucco is now beige instead of yellow and it only took a couple of hours for 2 machines.
                  Yes 3 of these units are in a design dept. with a fair amount of color printing.
                  Thanks again and hoping your living the dream.
                    • 23010
                    Yeah, that's a strange one. I can't say that I've ever noticed that feature, but we only placed 3 or 4 of the Falcon IV series.
                    As for living the dream ...
                    9 weeks. Hoping to start attempting to walk soon. =^..^=
                    • blackdog
                      • Jun 2012
                      • 211
                      [ATTACH=CONFIG]24361[/ATTACH]
                      Bummer!
                      Hey it was one of the crappiest winters all the way around. You should skiing on the lake in no time flat.
                      Good luck man.
