kyocera mita taskalfa 1800
  • Humble_me84
    • Aug 2025
    Anyone here how to reset toner cartridge error "non-genuine toner"? I have purchase this brand new copier and my friend recommended me to refill my cartridge if "replace toner" message flashes but after refilling the "non-genuine toner" flashes. My friend uses the same toner but it works for him. Please help. Thanks!
    • 23010
    Re: kyocera mita taskalfa 1800
    You got bad advice. These cartridges are chipped. Which means that it remembers that it's empty, forever, or until it sees a new chip.
    And what exactly did you refill it with? If it's not OEM (Original Equipment Manufacturers) toner, you are going to have a wide variety of problems that I won't even go into right now.
    The thing to do, is to throw away that cartridge. Then go to the store and but a new Kyocera toner cartridge, then install it. If you succeed in making any copies with that other crap in the cartridge, you'll have much bigger problems. =^..^=
