COPYSTAR CS-300i
  • JIMA1020
    • Sep 2012
    • 12
    COPYSTAR CS-300i
    COPYSTAR CS-300i---message on screen reads "can not use stapler due to failure. no other codes. this is a DF-780B FINISHER. CHANGED LIFT MOTER BUT DID NOT FIX. JUST SHOOTING IN THE DARK. ANY HELP IS APPRECIATE.
  • Zackuth
    • Aug 2009
    • 448
    Re: COPYSTAR CS-300i
    You're going to have to run a 906 reset first. The machine has disbled the stapler and will not work until the reset is done. After that you can troubleshoot the stapler issue.
    If at first you don't succeed, redefine success
      • 23010
      Don't just shoot in the dark. Once you've done that U906 reset, print the error log U000.
      If the code pops up before you get the print ... well there you go.
      Or, you could go to sim U904 to see what codes have been stored. Especially pay attention to the C8xxx codes. Those are the finisher codes. This information was available in your service manual. Then you can diagnose it just like a real copier tech. Open your manual and look it up.
      • kkendric
        • 301
        I do not understand, the stapler portion of a finisher does not work so you change the lift motor?
          • 23010
          Isn't it obvious? The lift motor is part of the finisher. The proximity of a new part will probably cure the stapler. That's why he didn't change the feed tires: too far away. =^..^=
          • habik
            • 2013
            I wonder if there is a point for kids to go to technical colleges to actually learn something. Or they will solely rely on the vast data availability online.
            Firmwares HERE
