Copystar CS 6030 "Time for maintenance" Message How to clear
  • Doug James
    • Jan 2012
    • 935
    [Error Code] Copystar CS 6030 "Time for maintenance" Message How to clear
    I looked in the service manual and cleared U904 and some of the other counters. The message is still their. Thanks so much for any help !!!
  • yakyitz
    • 245
    Re: Copystar CS 6030 "Time for maintenance" Message How to clear
    U251
    • Doug James
      • Jan 2012
      • 935
      Originally posted by yakyitz
      U251
      THANKYOU SO MUCH !!!!
        • 23010
        Did you actually do any maintenance? =^..^=
        • tonerleak
          • Mar 2012
          • 67
          That was gonna be my question.
          • Doug James
            • Jan 2012
            • 935
            lol... Yeah, these guys run 50,000 copies a month. So far no down time in 3 months. I put 2 (different) maintenance kits on it and watching the jam history. Been keeping it clean and so far so good...
            • JR2ALTA
              • Feb 2010
              • 2033
              how many millions on that old beast?
              • Doug James
                • Jan 2012
                • 935
                2,584,120... I am really impressed with that machine... very few jams. They say it's not 2 siding very well though. I'm going to look into that tomorrow...
                • Kidaver
                  Ghoulscout
                  • Apr 2011
                  • 912
                  If you've never changed the Duplex Switchback roller and you are at 2.5 mil...I'd replace that...it's a job but not too hard...also make sure the shaft and inside the white roller that sits above the DU switchback roller is clean and allowing the plastic roller to move freely...they get gunked up...
                  "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
                    • 23010
                    Ditto that. If you got 600K on the switchback roller I'd be happy. =^..^=
                    • monstott2010
                      properly serviced you will get a lot more of it.... we had one hit nearly 12mil in 5 years.....
                      • habik
                        • 2013
                        if I tell my boss he will never buy any other for the next 5 years lol...
                        I agree with good maintenance and mainly good training...5 mil. is always good. how many main drives have you changed so far?
                        Firmwares HERE
                        • Doug James
                          • Jan 2012
                          • 935
                          Main drive motors ? None yet... Had this machine for about 4 months so far... Are motors a problem for this ?... After sitting around for a few years before taken out of storage, I did have an issue with the developer motor. It hasn't become a problem since I put a new housing in it...
                          • habik
                            • 2013
                            arround 1.8 - 2.5 mil I have changed the main drives the motor and the gear running fuser will eventually wear out.. there is thread about this on the forum. I usually order the whole drive unit assembled in factory as there was a batch of spare motor shafts that had slight dimension intolerances and when put in the old drive unit it had a heavy drive and wear out quick or even worse produced issue, jam, noisy, C-code.
                            They good machines please don't get me wrong, as long as you have mods in they are sweet as a nut. Have you got the copper like looking springs on feed units ?
                            few good threads
                            Duplex:http://www.copytechnet.com/forums/sh...ght=km6030+mod
                            Jam 50 or 46
                            http://www.copytechnet.com/forums/sh...t=km8030+habik
                            Firmwares HERE
                            • Doug James
                              • Jan 2012
                              • 935
                              few good threads
                              Jam 50 or 46
                              This Info is SO HELPFULL !! THANKS SO MUCH !!!. (The springs were actually included in one of the kits and I installed them)
