Error c6000 on KM-4050
  • same_steven
    • Jun 2011
    • 52
    Dear friends,
    I have a KM-4050 machine with the above error...the machine does not go into service mode when I press 10871087. Immediately i switch on the machine the error pops up and it doesn't respond to 10871087. I opened up the keyboard panel thinking that maybe one key is not responding and on putting it back I now have the error CFB31. What going on here guyz?
    • 23010
    Re: Error c6000 on KM-4050
    Well for starters, you had a fuser error that required simulation U163 to reset. Then when you took off the op panel you plugged the 5 pin connector into YC9, not YC1 (they're exactly the same size).
    So for starters, power off, then remove the op panel again, and plug the 5 pin connector into YC1 to remove the op panel firmware error CFB31.
    Next, Run simulation U163 to try to reset the fuser error C6000. If it returns buy yourself a fuser, and run U163 again.
    Oh, and buy yourself a manual so theat you can figure these things out for yourself, and run these simulations properly. See Paul at www.justmanuals.com
    • same_steven
      • Jun 2011
      • 52
      Thankyou very much but I cant run u163 because the machine doesnt respond to 10871087
        • 23010
        Once you fix the op panel connector, you'll be able to get into service mode. Re-read the previous post. =^..^=
        • same_steven
          • Jun 2011
          • 52
          CFB31c fixed but still the machine wouldn't enter setup mode with 10871087. Is there any other way of clearing the error (c6000)?
            • 23010
            Nope. I'd try reloading firmware version 2.45a with a CF card, not USB. =^..^=
              • 23010
              It's not just 10871087. Read your manual. =^..^=
              • darry1322
                • Oct 2010
                • 817
                Open the front door before entering 10871087
                • same_steven
                  • Jun 2011
                  • 52
                  Guys, nothing seems to work...I upgraded the firmware using a usb drive since I didn't have a CF card. Is there a difference? The machine still doesn't enter simulation mode. Would changing the EEPROM work for me or I am doomed?
                    • 23010
                    Did you RTFM? It's Status > 10871087. Geez, do I have to do it for you? =^..^=
                    • kkendric
                      • 301
                      Press STATUS/job cancel, then 1087, 1087
                      • dedu
                        • Apr 2014
                        • 9
                        • Barış KURT
                          • Jul 2010
                          • 72
                          Değerli arkadasim Turkce yazarsan kimse anlamiyor,ayrıca 0614'u paylaşmasan daha iyi olur.
                          please english.
                          Black is Kyocera , Color is Gestetner.
                          • dedu
                            • Apr 2014
                            • 9
                            please english.
