Kyocera KM 505 driver and network install problem
  • Crni
    • Mar 2014
    • 54
    [Misc] Kyocera KM 505 driver and network install problem
    Hi,
    I wan't to install my km5050 on windows 7 64bit. When I plug it on usb it gives me just some unknown device and oem code.
    I run the Installer pack from Kyocera site and it won't detect the machine. After that I installed generic windows km5050 drivers but the Kyocera installer still doesn't see the machine.
    Printer is printing with generic drivers but I want to have all the options and network setup.
    Thx guys
    • 23009
    Re: Kyocera KM 505 driver and network install problem
    If you want all the network capabilities, don't you need a network?
    For starters I'd connect via TCP/IP not USB. If you don't have additional network ports install a simple switch. Then use the KX driver, because generic or universal drivers do not have all the features that you desire and they cannot recognize all the machine options. =^..^=
    • Crni
      • Mar 2014
      • 54
      You are right about network, lets ignore network for now.
      Installer won't detect my machine over usb and I can't install driver. It should detect it over usb right?
      PS
      Can I hard reset the machine without touch pad?
        • 23009
        Why do you assume it's a printer problem? It's much more common to have a dead USB port on you PC (especially Win7). If you insist on using USB, try another USB port or PC to confirm whether it's a printer or PC problem. =^..^=
        • Crni
          • Mar 2014
          • 54
          Ok. I menaged to install drivers over usb Now I have to figure how to get IP details from the machine without touch pad
          • habik
            • 2013
            Firmwares HERE
            • Crni
              • Mar 2014
              • 54
              Is there a way to tell the machine to scan and sent from PC, not using a touchpad?
                • 23009
                TWAIN scanning can be done, when you set up a network connection, not USB. =^..^=
                • Crni
                  • Mar 2014
                  • 54
                  Installed the network Now I have to see that Twain option. Is that a separate utility?
                    • 23009
                    Yes. Download and install the TWAIN driver:
                    You haven't specified what country, so I'll assume US-English. If you want something else, it will be found easily on this website. =^..^=
