km 4035/5035
  • Users Tech
    • Nov 2013
    • 85
    km 4035/5035
    hello all,which part of the fuser that causes c6050 on a km4035/5035? i searched it here but the solutions i have read was to use 163 or replace the fuser. i would like to know which part of the fuser shall i replace.thank you in advance.
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    Re: km 4035/5035
    The service manual has a description of the problem and a list of suggestions on what to try to fix the issue.
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
    • cm79
      • 20
      Re: km 4035/5035
      you either have a bad thermistor, thermostat, or heater lamp.
        • 23007
        Re: km 4035/5035
        This seems pretty elementary. Do you know how to test each of the three electrical components? =^..^=
        • kkendric
          • 301
          Re: km 4035/5035
          If you cannot troubleshoot a basic fuser problem then, please step away from the copier!
          • Users Tech
            • Nov 2013
            • 85
            Re: km 4035/5035
            thank you cm79. sorry for this very simple question. i'm a ricoh tech and is just starting with kyocera's.
            • MR Bill
              • 532
              Re: km 4035/5035
              Well you will like working on Kyocera equipment then. I like them over Ricoh products. But anyway , Like what was mentioned , Thermistor, or lamp etc. I can sell you a used fuser cheap if you would like . If you are just starting you will need parts. Easy to install a fuser and then repair the old one in you shop. ?? First thing to do is try to reset the code. Sim 161? OH and by the way. You do have a manual , RIGHT?
              • kkendric
                • 301
                Re: km 4035/5035
                Actually the reset code is 163. Most fusers should require the same troubleshooting skills. Most of the Kyocera products have a disable feature for certain portions of the copier, however the fuser has its own. If a cassette, LCF, DP or DF error out they can be reset by sim 906.
                • MR Bill
                  • 532
                  Re: km 4035/5035
                  OPS, going by memory. Yes sim 163 for fuser reset. Sim 161 changes fuser temps. Got it.
                  • habik
                    • 2013
                    20 quid in pdf or 5 hrs on forums. I am always opting for manual! If it ain't in manual then its time for threading! Rant ovet.
                    Sent from my iDon't believe in marketing device using Tapatalk
                    Firmwares HERE
