KM-5035 Legacy Model
  • jeromeblanks
    • Jul 2010
    • 13
    I have a KM-5035 that has intermittent CQ problems. Sometimes I get a 4 to 5 inch void in the middle of the page when doing a lage copy job over 500 when running under a 100 copies at a time it works perfect. The DV Unit , high voltage board, power supply and drum has been replaced no change and power has been tested also.
    Any Ideas
    • 23010
    Re: KM-5035 Legacy Model
    How about a sample? =^..^=
    • stevena86
      • Oct 2012
      • 130
      Samples would really help as Blackcat stated. Also, only things to cause voids are the laser unit glass being dirty or the transfer section. Check your transfer roller.
      • thekeg19
        • 29
        Did you replace main charge w/drum unit? Youtr post didn't specify.
