Kyocera km3035 with error c4200
  • daveh12
    • Jul 2012
    • 157
    [CQ] Kyocera km3035 with error c4200
    hi all, any help really appreciated
    Firstly I know there are a lot of other threads on c4200. I have read them and tried all they suggest.
    I have replaced main charger, grid, drum unit, developer unit,transfer roller, LSU, power supply board, even went as far as replacing main pwb. Firmware updated. All connections are good. But still every now and again C4200 WILL appear.
    Black cat had some good suggestions in other threads but as yet nothing has worked in stopping the reoccurance of this code. Any other suggestions are greatly appreciated.
    Thanks guys.
  • dedu
    • Apr 2014
    • 9
    Re: Kyocera km3035 with error c4200
    selam
    lazer unitesini değişmen gerekir
    • Tonerkiller
      • Oct 2012
      • 668
      It is the charge arcing.
        • 23009
        As much as I agree Tonerkiller, he seems to have covered the most likely culprits.
        Just fishing ... have you put the power quality analyzer on the outlet yet? =^..^=
        • daveh12
          • Jul 2012
          • 157
          No black cat I haven't. You think it could be an unreliable power source?
          • darry1322
            • Oct 2010
            • 817
            Missing grounds can cause false malfunction codes.
            • rashid120
              • Jun 2010
              • 76
              Thanks guys.
              please check the front door switch.
              Thanks and Regards.
              Rashid
              • MR Bill
                • 532
                Yes, I think interlock switches may cause this problem. Might just install new switches.
                • kkendric
                  • 301
                  Has been caused by front door switch agree with Rashid.
                  • Zackuth
                    • Aug 2009
                    • 448
                    There is a fan that cools the LSU, is that working properly? Maybe the LSU is overheating and popping the code.
                    If at first you don't succeed, redefine success
                    • Barış KURT
                      • Jul 2010
                      • 72
                      switch interlock have caused c2000 ,
                      i think bad power source , ground line (low voltage etc.) , or short circuit on LSU cable line.
                      Black is Kyocera , Color is Gestetner.
                      • daveh12
                        • Jul 2012
                        • 157
                        Thanks for the ideas. Will let you know how I get on.
                        • quitech
                          • 82
                          Hi my good frd,
                          please how did you solve this problem of c4200?
