kyocera FS6025 command center.
  • Barış KURT
    • Jul 2010
    • 72
    hello ,
    I want close fs6025 web interface (command center) ,because every user can reach over IP.
    Or what can I do, only access my static IP ?
    Regards.
    Black is Kyocera , Color is Gestetner.
    • 23008
    Re: kyocera FS6025 command center.
    What do you expect your users to do? Change the network settings?
    Most endusers won't remember how to edit the addressbook, even after reminding them repeatedly. Your worries are unfounded.
    Or are you like these tight-assed IT guys that lock things up just because they can?
    • stevena86
      • Oct 2012
      • 130
      I change the admin password everytime I'm at a copier whose password was changed by their IT.
      I am the admin, not you; IT man!
      That is my playground! You have your own!
      • Barış KURT
        • Jul 2010
        • 72
        So , Our machine is Olivetti 253MF plus. (Fs 6525MFP ) .Every user can reach and edit "adress book" without admin password.
        My customer does not want it.
        • Eric1968
          • 2458
          Blocking the IP-adress of the machine for HTTP-traffic is an option. But the customers also can make changes to the adress book on the machine itself, so you'll also have to lock the machine.
