km5035 and km2050
  • Franky Tan
    • Aug 2025
    km5035 and km2050
    I have 2 problems here , 1st one is km5035 after its show c2500
    a few time i replaced lifting motor on 1st tray but its shown c1010 after a few weeks , i need solution, please .
    2nd problem km2050 show JAM11 when make copying but meter counter still low.Another km2050 meter counter is 250k its show JAM41 when make copying .thankyou
    • 23010
    I take one of those:
    On the CS-2050 with the J11 jams: It very common for the customer to get a jam 1/2 way through the feed/separation rollers, then pull out the cassette forceably. The separation roller becomes unlatched from it's mounts and will give you lots of those J11's after that.
    The easy way to get to the separation roller is to remove the waste bottle, drum unit, and developing unit. Tip the machine up onto its left side on the floor (with the door closed, of course).
    • Two Medicine
      • Sep 2007
      • 20
      The C2500 is usually caused by the left side door being pulled while the machine is operating. It gives you a false paper feed code and is really due to the safety switch and two other switches ganged together on the left rear frame area of the copier. These switch/switches are being opened during operation and then pop the code. More prone to occur if the customer has a finisher attached also and the finisher is placing pressure on the left cover allowing the cover to get pulled open slightly and opening the switch/switches.
      • 10871087
        • Jan 2005
        • 1062
        [quote=blackcat4866;31855]The easy way to get to the separation roller is to remove the waste bottle, drum unit, and developing unit. Tip the machine up onto its left side on the floor (with the door closed, of course).[quote]
        No shit, Probably the most inconvenient Kyocera paper feed system to work on since the DC-4585 Duplexer.
          • 23010
          I've pulled a few of those. It's been so long that I can't even picture it now.
          • Franky Tan
            THANKYOU TO ALL
