Kyocear mita 2050
  • Rakesh Khambholja
    • Sep 2013
    • 17
    Kyocear mita 2050
    After power on machine shows jam code 00. I have replaced sensor paper path, exit both. Replaced engine pwb. Any solution ?????
  • Paddy
    • Jun 2013
    • 9
    Re: Kyocear mita 2050
    Hi,
    here is what I've found in the Service Manual:
      • 23009
      As you probably already know, J00 means that paper is present at any paper sensor at power ON. Not a specific paper sensor. Any paper sensor.
      If I were you, I'd go into service mode and check the state of each sensor to determine which one is actuated. It's a lot easier than just randomly replacing all of them. =^..^=
      • MR Bill
        • 532
        Wow. I have sold those machines for over 8 years. Have about 60 in the field. I never knew that cat. I would have had to get out the manual. So I bet a tiny piece of paper is blocking a jam switch. There is a switch lever right below the drum assy. And the spring that pulls that lever back comes off sometimes. Maybe that spring is gone and the lever is not in proper position?
          • 23009
          Sure. It could be any of them. =^..^=
