CS-5050 Jams J14 every time
    • 23008
    Talk about a totally stupid thing downing a machine: this CS-5050 keeps trying to pick up from an empty bypass tray. Why? Because a plastic C-clip was installed backwards. The flange on the clip lifts up the PE flag when the lift clutch rotates. Paper appears to be present, and it attempts to feed the imaginary paper. J14 results.
    This is the way the clip should be installed.
    Sorry, it appears that the photos came out upside-down. Stand on your head while viewing photos. =^..^=
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: CS-5050 Jams J14 every time
    That is a rookie mistake...obviously didn't check it well
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • 23008
      I won't dispute that. Fortunately I wasn't that rookie. =^..^=
