CS-5050 Reading paper incorrectly on DF
  • ClarkIR
    • Oct 2013
    • 74
    Ive got a 5050 that started acting bizzaro from nowhere
    If we put in the paper 11x8.5 in the DF, the Machine says "inappropriate paper size, please add ledger paper"
    If we put it in 8.5x11, it does the same thing, except requests legal paper.
    Did a 906, 21, and even replaced the DF... None of these resolved the issue.
    Documents reading correctly on the glass.
    Anyone got a suggestion or know what might be up? Firmware is up to date.
  • ClarkIR
    • Oct 2013
    • 74
    Re: CS-5050 Reading paper incorrectly on DF
    I want to clarify, DF i am referring to Document Feeder.
    • copymech
      • Sep 2011
      • 196
      Sometimes very bright lights above the DF will cause it to read wrong paper sizes. Try it with the lights off. I have encountered this many times over the years. Usually happens after replacing light bulbs or machine is put near window without blinds or curtains to prevent direct sunlight.
        • 22999
        I'd check to see if there is a calibration for the sensitivity of the original length sensor. You should be able to test it in simulation.
        I also like copymech's bright light theory. I've seen it on plenty of other models. On one particular occasion the enduser only had the problem in the morning, and was of smaller stature (altitudinously challenged). Taller endusers managed to block the direct sunlight with their body, or by standing in a certain location. =^..^=
        • Tebow83
          • May 2009
          • 92
          Sometime dirt can get in on the size detector pcb's and cause the machine to read false paper sizes. Try cleaning them.
          • Tonerkiller
            • Oct 2012
            • 668
            My vote is that the floresent lights above the copier are the issue. I am sure that you cleaned the length dect sensor.
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              i would check the df closed sensor, may be popped out of position
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
              • ClarkIR
                • Oct 2013
                • 74
                ended up being some low hanging cabinets right above the sensor. moved the copier out, no more issues.
