kyocera taskalpha 500ci c7000 eror codes
  • walterman
    • 196
    I am working on a kyocera 500ci with c7000 error codes. I seen the tsb about the motor changes. The tec bulitan says to replace the toner container motor, location e. I have ordered the motor however, I can not locate it. I have basically torn apart the entire mfp, spent about 4+ hours on it and still can not locate the motor location. The mfp has kicked my ass so Im asking for some help.. it would be greatly appreciated!
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: kyocera taskalpha 500ci c7000 eror codes
    You get to it from the front. Remove the rear cover above the internal catch tray and bingo. It should take you about 20min.....
    The gene pool could use a little chlorine.
    • walterman
      • 196
      Thank you, JSC... that is the only area I did not remove but I will on Monday or Tuesday and let you know the final outcome. I owe you one! Love the gene pool and chlorine quote..lmao!
      • walterman
        • 196
        Sorry, JHC... love the quote by the way..lmao!
          • 23008
          What I usually do when I cannot locate an electronic component is to read the part of the service manual called "Location of Electronic Components". It can be very helpful. =^..^=
          • walterman
            • 196
            I could not agree with you more, Blackcat.
            • walterman
              • 196
              Thanks for all the input, I installed the motor, however, I'm still getting the error which could be caused by backed up toner ( I'm assuming), but here is the kicker, the customer asked me if I could bring the mfp back to the shop because their building was in foreclosure and the building was going to be locked up as of that night. So, I transported it back to the shop and have not looked at it since. Once, I hear back from the customer, when they find a new building (church), they will call me back and we will go from there. Thanks again!
              • ss12
                • Jul 2008
                • 289
                If the dev units are not backed up it could be the engine pcb.ive had this issue before.BTW the motors are interchangeable if you want to check them
                Sent from my iPod touch using Tapatalk
