km 5050 will not print... or fax...
  • n25an
    • 1030
    Ok... here is what I have done...
    customer complained that machine was unable to print or fax... after move...
    I updated firmware... no change
    performed 20, 21, 906 and 163... no change
    I found a working machine at shop... a km 3050... I took the dim... the hard drive and the ram... and 2 extra hard drives 80 gb each...
    I switched dim... no change...
    performed firmware upgrade... no change...
    switched ram... no change...
    performed firmware upgrade no change...
    switched hard drive no change...
    did the hard drive firmware thing three times... no change...
    I took the machine back to the shop...
    took out the engine board I believe its called... checked all connections...
    pulled the engine board ( board with ethernet port) from the km 3050 put the km 5050 engine board rom ( board with ethernet port) on it...
    stuck the km 3050 engine board( board with ethernet port) in the km 5050... now machine prints scans and copies... haven't checked the fax yet...
    my question is there any way to unblock the original km 5050 engine board... ( board with ethernet port)
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • johnyb
    • Feb 2011
    • 167
    I have encountered a similar issue a few years back on this product...
    I don't recommend doing this normally and only did it as a last resort, I cleared the nvram!
    Also worth a shot...
    I can't remember if this product has this feature .. But on Ricoh you can put on access control list ip range.
    And unless you put the machine in that range and laptop, if you are crossing over, you won't be able to communicate with the machine.
    • Kyo fan
      • Dec 2013
      • 368
      Re: km 5050 will not print... or fax...
      The board with ports is the main board, engine is next to it. Sometimes it goes bad and you can't do anything untill you replace it. I've had instances where ethernet port dies but usb port still works on it, no error codes or anything.
        • 22983
        Same situation. The machine printed to USB, but no longer communicated by TCP/IP. The enduser got a "good deal" on the machine because it couldn't print.
        • BSGINC
          • Jan 2012
          • 19
          I have had this problem on two machines the solder connections on the main board for the ethernet RJ45 were "cold solder" joints I simply touched them up with a low watt soldering pencil and they have worked fine ever since 2+ years.
          • n25an
            • 1030
            ok.... I started working more on the km 5050 today.... I started getting a cf630 when machine came out of sleep mode.... at this point... I decided to move back to the 3050... I felt that this was the most viable option... upon moving main board with nic and hard drive over... cf630 error followed... tried formatting... issue only went away... when I changed hard drive... is there any way to recover hard drive when this happens... I am thinking about formatting on pc and clearing it... but not sure if this is the best idea...
            back to the km 5050... changing the hard drive might have been a good fit... but at that point my mgr said... lets go with what works.... so km 3050 was what happened...
            I am curious does anyone here think that changing the km 5050 hard drive would have cleared up the error...??? keep in mind... I am using a km 3050 main board...
            also how do I clear the nvram... ???
            • n25an
              • 1030
              by the way I tried clearing the hard drive on the machine... with format... and all the other memory options...
              • kkendric
                • 301
                Possibly the key here is "after move"
                1. Does copier make copies with the CS/KM-5050 Main board?
                2. Have the RJ-45/USB connector pins been inspected for damage? sometimes users forget to disconnect before moving and damage the connector.
                3. Was DHCP on or off?
                4. By keeping the CS/KM-3050 main board in the copier you will only have a slower copier by twenty PPM.
                5. If it was working before it was moved it should work after the move, unless it was damaged or the parameters of operation have changed. You do not mention any attempt at viewing, checking or changing any of the network settings just attempting to upgrade the firmware a bazillion times, swapping HDD multiple times and downgrading the main PWB to30 PPM.
                • n25an
                  • 1030
                  ALL MY RESPONSES ARE IN RED... AND I AM NOT SHOUTING... CAPS LOCK JUST STUCK
                  BEFORE MOVE... NOTHING WORKED... AFTER MOVE CHANGED BOARDS... SWITCHED ROMS... PRINT WORK... SCAN WORK... FAX STILL DEAD... SWITCHED FAX BOARD... FAX WORK... ONLY ISSUE... WHEN COMING OUT OF SLEEP MODE FIRMWARE ERROR... MACHINE LOCKED UP...
                  1. Does copier make copies with the CS/KM-5050 Main board? YES
                  2. Have the RJ-45/USB connector pins been inspected for damage? sometimes users forget to disconnect before moving and damage the connector.NO BUT WILL CHECK ON MONDAY
                  3. Was DHCP on or off?IN BOTH CASES NO PRINTS BEFORE MOVE
                  4. By keeping the CS/KM-3050 main board in the copier you will only have a slower copier by twenty PPM. YES IT WILL BE SLOWER BUT IT WILL HAVE FIRMWARE GLITCHES WHEN COMING OUT OF SLEEP MODE...
                  5. If it was working before it was moved it should work after the move, unless it was damaged or the parameters of operation have changed. You do not mention any attempt at viewing, checking or changing any of the network settings just attempting to upgrade the firmware a bazillion times, swapping HDD multiple times and downgrading the main PWB to30 PPM. NETWORK SETTING CHANGES WERE APPLIED PREVIOUS TO THE MOVE.... THEY HELD WHEN STATIC AND DID NOT CHANGE WHEN DHCP... BUT MADE NO DIFFERENCE AS TO PRINTING... MACHINE STILL NOT PINGABLE OR DETECTABLE ON NETWORK.. THIS WAS ALL DONE PREVIOUS TO MOVE... I APPOLOGIZE FOR ANY CONFUSION...
                  • kkendric
                    • 301
                    This explains my confusion.
                    This indicates to me that everything was working until the machine was moved.
                    If the RJ45 is not damaged sounds like the Network IC has gone bad.
                    • n25an
                      • 1030
                      it was a slow day... so the manager assigned it to our local printer god... ok... here is what he found... yes... the rj45 network port... had issues.... more precisely.. the pins inside were bent... so no connection was taking place. the next thing was the cf640 and cf630 when exiting sleep mode... local printer god... took the hard drive from a km 4035 stuck it in and the code has gone away...
                      local printer god... deduced they were damaged due to the move... as for the hard drive... he blames me for overthink... I can't deny that... ok... as far as the fax... the only thing that he can think of is that the fax line had not been set up as yet...
                      so currently this issue is closed...
                      I have one question though... kyocera hard drives... if I write all 0s and 1s to the hard drive... and then format the hard drive in the copier... it should work unless... there is an issue with the hard drive... correct?
                      Just trying to recover the hard drives that gave the cf codes... all help is appreciated...
                      • Kyo fan
                        • Dec 2013
                        • 368
                        Thanks for sharing.
                        Yes the hard drive (you don't have to call it Kyocera, since it's just a regular smaller capacity 3,5 inch hard drive) will work handled that way unless it has problems like bad sectors, etc. Also bigger capacity hard drives can pop error codes in older machines when installed, so make sure (if you can obtain) to use same capacity and preferably same vendor hard drives when replacing, which can be tricky these days.
                        • n25an
                          • 1030
                          thanks...
                          Thanks for sharing.
                          • MFPTech
                            • 486
                            Kyocera uses HDDs only to store the address book and for spooling. You can replace them with any HDD and formatting in the copier is not necessary. In some models Kyocera uses 2 HDDs in RAID 1 (stripping) for performance. I never order HDDs from Kyocera, just try to recover them or buy new ones from local computer stores.
                            Good luck!
                            • kkendric
                              • 301
                              Congratulations on getting it working again. I am a circuit board repair technician and have seen many RJ45/USB damaged by users moving copiers.
