Firmware V11
  • blackdog
    • Jun 2012
    • 211
    Firmware V11
    I had to order a black developer unit for TA250ci but requires Version 11.
    Not sure what will happen if black dev is installed with current version firmware?
    Anyone have this version 11 or knows where to get it.
  • copymech
    • Sep 2011
    • 196
    Re: Firmware V11
    If you get an error 74-- for example. Just swap the chip between the old and new. It will work like a champ.
    • rashid120
      • Jun 2010
      • 76
      Re: Firmware V11
      just install, it will work fine.
      Thanks and Regards.
      Rashid iqbal
      • blackdog
        • Jun 2012
        • 211
        Re: Firmware V11
        Chip?
          • 22999
          Re: Firmware V11
          Kyocera changed the developing coupler on the back of the DV units. At the conclusion of a print or copy job the developing motor reverses causing the coupler to ratchet. The ratcheting action provides enough vibration to shake back down some of the toner that has been dumping all over these machines. Of course for all of it to work properly, you'll need version 11 of the firmware.
          My recommendation is to get the firmware. Your machine will run cleaner. =^..^=
          • blackdog
            • Jun 2012
            • 211
            Re: Firmware V11
            Wow, I am impressed!
            I would almost beleive you were a HAL 9000. Hmmmmm
              • 22999
              Re: Firmware V11
              You and your customer will notice the difference. There is a noticeable fast tic, tic, tic, tic, ... at the conclusion of each job, and it is supposed to do that. =^..^=
              • blackdog
                • Jun 2012
                • 211
                Re: Firmware V11
                Sounds like it will "take a lickin & keep on tickin"
                Tonerkiller is going to send me over the firmware.
                Any tips on your proper setup of dev other than what's in SR?
                  • 22999
                  Re: Firmware V11
                  The machine automatically does its own stir when it sees the new EEPROM (chip). Kyocera serializes all of the developing and drum units. That's the drawback to swapping chips. The machine never does a new stir.
                  Do the firmware first, then the dev unit. Just do a complete color calibration and you're all set. See:
                  http://www.copytechnet.com/forums/ky...tml#post232226
                  • blackdog
                    • Jun 2012
                    • 211
                    Re: Firmware V11
                    Very informative link, thanks.
                    And yes that other post is related to this one.
