FSC-8500dn
  • komakino63
    • Aug 2025
    FSC-8500dn
    hi I have an issue with this printer where black keeps fading, perform dev refresh and works for few days this has been ongoing problem since install, fitted both maintenance kits and now the same thing is happening with new dev, going to try another dev unit and front main and sub pwbs but any ideas would be helpful,
    cheers
  • DWise
    • 895
    Re: FSC-8500dn
    Is EcoPrint on? Check other Print Settings? Using OEM toner?
    Do for one what you wished you could do for everyone. - Andy Stanley
    • komakino63
      Re: FSC-8500dn
      ecoprint off, using genuine toner, print settings ok, seems like toner starvation.
      • copyguy1
        • Jul 2011
        • 142
        Re: FSC-8500dn
        Having the same issue. We have tried 2 different DV units. And the customer called back today saying that the blacks are really washed out again.
          • 23010
          Re: FSC-8500dn
          All the Saturn bulletins will apply to this machine equally. Particularly the developer motor/cleaning motor bulletin. Firmware current? =^..^=
          • copyguy1
            • Jul 2011
            • 142
            Re: FSC-8500dn
            we updated the firmware just before replaceing the last DVunit.
            • copyguy1
              • Jul 2011
              • 142
              Re: FSC-8500dn
              Machine seems not to be adding toner enough. Was looking at ordering toner motors but having trouble finding them in parts book. I was thinking it was part of Fig 21. Just looking for verification on this. Thanks
                • 23010
                Re: FSC-8500dn
                I have seen dead and slow running developer motors. I've never seen a faulty Saturn toner motor. The way you can tell the difference is to look in the toner spout of the developing unit. Is there an unmixed pile of toner, yet it's still asking? Then the developing unit is not agitating. Is the toner thoroughly mix in? Then you may have a toner motor problem. Or the toner cartridge may be seized up.
                As likelihoods go, I'm leading towards
                1) the developing motor
                2) compacted toner in the cartridge
                3) the toner motor
                But of course, it's up to you. Look at the Saturn bulletin. =^..^=
                • Las Kona
                  Re: FSC-8500dn
                  try checking the firmware and then upgrade, but if it started when installed, best to return to manufacturer.
