KM 4050 Cass 1&2 Not working
  • kmtech
    • Sep 2008
    • 125
    I just took this machine in on trade and getting it ready for the field, tore it down and put it back together the 2 primary cass not loading paper. I wondering if the main board is bad? I tried the motor from another machine that worked, still no motor! just wondering if any one had a idea before i send the main out....
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: KM 4050 Cass 1&2 Not working
    what does "not loading" mean? not lifting, not feeding?
    any codes?
    did it work before you started refurb?
    • Max
      • Oct 2011
      • 561
      Check for the paper bits in the paper tray connector on the copier side and the tray side. A very small amount could be well packed in the connectors
      • kmtech
        • Sep 2008
        • 125
        any codes?
        the machine says no paper in cass 1 or 2 and the motors dont operate, there by paper is not being loaded!
        • kmtech
          • Sep 2008
          • 125
          I checked it, thanks
          • kkendric
            • 301
            Did they work before you took it apart? Have you gone into the service mode and executed sim 906? There are some surface mount components that sometimes go on the engine board when the lift motor goes, but at least try Sim 906.
            • kmtech
              • Sep 2008
              • 125
              not really sure if it did or not work before. yes i did the 906, i was going to try another Main board but some one said not to cause if the motor were short it would take the other board out..
              thanks alot for your help...
                • 23009
                A shorting lift motor will blow the driver circuitry on the engine PWB. If you had one tray that worked and one that didn't, and swapped the motors, it would blow the other driver circuit, and neither would work.
                Order two lift motors and an engine PWB. Replace them all as a set. You may have to do a U906 when you're done. =^..^=
                • kmtech
                  • Sep 2008
                  • 125
                  thanks, i guess i will bite the bullet..
