Kyocera 3530 laser
  • Navy
    Brown Shoe Sailor
    • Jul 2006
    • 48
    Kyocera 3530 laser
    befor I tear everything apart, is is possible to open up a kyocera 3035 laser and clean out the polygon mirror motor assembly? I have one with an intermittant code that cleaning might help.
    NAVY - Never Again Volunteer Yourself
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    I wouldn't take one apart. But, thats up to you. We just reciently had a 5035 giving intermittent 4200 code that ended up being caused by the main charger. There were no other codes. Just the c4200. The customer finally showed us a print b-4 the machine threw the code. Duh... we even changed the laser before they showed us the test print. New charger....no more problem...
    My mission here on Earth is to help all you Dum-Dums!
    • Mark B
      • Jul 2006
      • 153
      Its the charge unit
      • 10871087
        • Jan 2005
        • 1143
        Originally posted by Mark B
        Its the charge unit
        I agree, try the charge unit first, cleaning it sometimes doesn't help?? just replace it since it's a relatively inexpensive part.
        • cboucher
          • May 2025
          It's possible to take apart the laser unit and clean it. Try cleaning mirrors and beam detect sensors. More than likely though, you will have to end up replacing the laser if that's the problem. (I've only seen cleaning work a couple of times).
