FS-C2526MFP error C6000
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5017
    I'm canon tech and need some help with with this color machine.I assumed that the rolled paper in the fuser cause of the error but the error is still present.In service manual does not say anything about resetting this error.I check service mode on the machine several times.Some ideas maybe?
    Thanks in advance!
  • Zackuth
    • Aug 2009
    • 448
    Re: FS-C2526MFP error C6000
    These models do not have a fuser reset. If you're still getting a code you need to replace the fuser.
    If at first you don't succeed, redefine success
    • zoraldinho
      • Mar 2008
      • 5017
      Crap! This is first jam.Machine have total counter 1080 copies.Just don't get it! Thaks Zackuth.
      • Zackuth
        • Aug 2009
        • 448
        The rolled paper must have broke or damaged a sensor.
        • zoraldinho
          • Mar 2008
          • 5017
          Broken sensor can't be a reason for error but termistors looks ok.
            • 23010
            How about the obvious? The wrapped paper insulates the thermistor from the heat roller. Temperature continues to rise until it blows the thermostat. This thermostat can't be so unique that you can't scrap one. =^..^=
            • zoraldinho
              • Mar 2008
              • 5017
              Thanks for the obvious but usually machine have protection so if in a few seconds can't reach specified temperature throws error code.
                • 23010
                You're welcome. It's my specialty. =^..^=
