General Falcon engine question
  • Scottb
    • Apr 2013
    • 308
    Ok so I have seen this little filter that is taped to the dv unit when it comes in a maint kit. Where does this guy go I have looked in the parts book but well there are only so many filters and this one does not show up in the pdf search.
    Thanks,
    Scott
  • darry1322
    • Oct 2010
    • 817
    Re: General Falcon engine question
    Sounds like the filter that goes into the top of the DV unit. Long and narrow, black plastic with white filter material?
    • Scottb
      • Apr 2013
      • 308
      nope its just a black sponge like material a inch or so square. it comes in a bag and its taped to the dv unit bag
      • darry1322
        • Oct 2010
        • 817
        That sounds like the sponge that would be used to seal the open toner port of the old unit. It also has a white/yellow tape in there to tape the sponge to the hole. It's used to keep the old unit from spilling toner everywhere after it has been removed.
        • Scottb
          • Apr 2013
          • 308
          yep that sounds like it thanks it has sort of bugged me for the last 4 years not knowing where this went and I have meant to post but always forgot by the time i got back to the shop.
          Scott
            • 23010
            Confirmed that. =^..^=
            • JR2ALTA
              • Feb 2010
              • 2033
              Wow, to think we used to actually have PM kits!!
              One box, one part number brought your copier from zero to hero in 45 minutes.
              Sure made refurbing machines a lot easier.
              Konica Minolta refurbs are a crap shoot....a long, tedious crap shoot.
