taskalfa 3050ci error after change dv m
  • AngusYoung
    • Aug 2012
    • 22
    Changed in the printer development unit magenta and the print quality was poor.
    Magenta periods over the entire sheet. Calibration is performed.
    pic here https://plus.google.com/u/0/photos/1...20402926187457https://plus.google.com/u/0/photos/1...20402926187457
  • darry1322
    • Oct 2010
    • 817
    Re: taskalfa 3050ci error after change dv m
    If it wasn't doing this before you changed the magenta developer, then the new unit is probably defective.
    • AngusYoung
      • Aug 2012
      • 22
      was
      and now
      period similar to the circle of the magenta shaft of the magnetic drum .
      And this problem does not occur for the first time. The last time helped the new firmware and cleaning contacts. What exactly helped in that time did not know and had a problem with yellow.
        • 23008
        I'll have to agree with darry. If the problem is introduced with the new magenta developer, then that's the most likely source of the problem. =^..^=
        • AngusYoung
          • Aug 2012
          • 22
          If the problem persists, and with another new development unit of the new kit?
          And me, I immediately and the developing unit and drum.
          • NeoMatrix
            Senior Tech.
            • 3513
            Looks like a dev bias ground fault or ITB inner roller fault ???
              • 23008
              I was thinking similarly:
              check charge contacts
              check transfer belt to HVT contacts
              Is it OEM toner?
              • ES-OGT
                • Aug 2011
                • 129
                Make sure you run the AC Calibration once you replace these. I've had that solve this problem before. Otherwise it's a bad DV unit.
                • AngusYoung
                  • Aug 2012
                  • 22
                  u464 ?
                    • 23008
                    Originally posted by AngusYoung
                    u464 ?
                    Yes. If you look at the insert, Kyocera recommends that you run U464 twice. Both before and after color registration. =^..^=
                    • FrK
                      • Feb 2013
                      • 4
