Booklet Finisher Creases? TA5501i , BF-730
  • bgkahuna
    • Aug 2008
    • 17
    [Misc] Booklet Finisher Creases? TA5501i , BF-730
    Hi guys,, On a kyocera taskalfa 5501i with a booklet finisher. the booklet finisher is the bf-730. Is there a way to adjust the amount off crease/fold that it creates? The customer says that it use to put better folds on his books and now it doesnt fold very well. The only adjustments i found is for the positioning of fold or position of the staples.
    thanks.
    • 23010
    Re: Booklet Finisher Creases? TA5501i , BF-730
    The amount of fold is the product of three factors:
    1) The amount of pressure, applied by some big beefy springs.
    2) The positioning of the knife.
    3) The type of media your enduser is using.
    Of all of these the main thing that you don't have any control over is your enduser feeding 250 g/m2 media, and telling the machine it's plain paper (because the folder isn't designed for 250 g/m2 paper). Look at the media. Read the specs. Then tell them it's just not designed to do that. =^..^=
    • jmaister
      certified scrub
      • Aug 2010
      • 755
      it creases on plain sometimes... dunno what to tell me clients.
      Idling colour developers are not healthy developers.
      • habik
        • 2013
        So I presume booklets are fold and stapled in centre and you have creases on the paper from left to right on booklet assuming the cetral fold(crease) is from top to botom, right?
        Or is it just fold crease that is out of the middle slightly and the edges don't bind nicely as if you need extra cut?
        Have you cleaned the main rollers on the booklet maker!
        Sent from my iDon't believe in marketing device using Tapatalk
        Firmwares HERE
        • Tonerkiller
          • Oct 2012
          • 668
          I have found that if the staple is right on the fold, the fold is not to pretty. Adj. the staple position so that the staple is not right on the fold. I move it toward the back a little.
