Alphard 3050ci
  • Spk
    • Oct 2014
    • 8
    [Dead] Alphard 3050ci
    Hello,
    im new to Kyoceras, having come from a Canon background,
    recently I swapped out a black drum, upon rebooting the
    machine the waste toner pot error msg appears and will not clear,
    having remade the the waste toner connecter and stripped and cleaned out the sensor the issue remains,
    any help would be appreciated,
    regards
    • 23010
    Re: Alphard 3050ci
    Is the neck of the bottle clean? My guess is that you dumped the waste toner, filling those two little pockets right in the neck of the bottle with toner. If the optical sensor cannot shine light through the neck of the bottle, it's full. =^..^=
    • Spk
      • Oct 2014
      • 8
      Re: Alphard 3050ci
      Thanks,
      bottle has been replaced,
      this has happened on the older 300ci series and has cured the problem,
      but not this time,
      regards
        • 23010
        Re: Alphard 3050ci
        I've only had one machine in recent history giving false waste bottle messages ... it was a bizhub 364e (the monochrome version). I believe the consensus was that the bottle detection photointerrupter had failed. Unfortunately that photointerrupter was permanently affixed to the front main PWB, but I believe warranty covered it. =^..^=
        • tonerlung
          • May 2008
          • 27
          Re: Alphard 3050ci
          make sure that the connector for the hopper assembly is fully in. During the hopper removal when replacing the drum it is possible you may have pulled one of the other connectors off.
          • Spk
            • Oct 2014
            • 8
            Re: Alphard 3050ci
            Thanks, but all the connectors have been remade,
            • copycoan
              • Sep 2012
              • 31
              Re: Alphard 3050ci
              one time i replaced waste toner container and the message was remaining, after a while watching i realized one door was not closed correctly and that was the problem, it seems like machine do no reset an error message if get another one and go on showing the first error even if solved...
