Hello,
I have a Kyocera KM-2530 that's been moved to an old room as a backup copier. This copier still works great but had no Print System board installed for network sharing. I saved a board from another copier we had before it was cannibalized by our vendor and installed it in this one. As far as I know they were the same models but the neither one was used on the network (copier only).
The copier was able to boot with this card and I could find the IP address in the printer menu. I tried to print to the copier over the network and it stalled at processing.
Now I can't get the printer feature to get passed the "Self Test" screen after boot. It just sits at that window and you can only use the copier function.
I can still ping the print board and login with telnet to the IP but that's it.
Few questions about the board:
It had no memory installed. Does it require memory? Regular PC100 SDRAM? Or a special type?
What are the jumper settings for the IB-21E for a network reset?
Also, tried printing via parallel with no luck (could be that the board no longer gets passed self test).
Is this copier worth investing the time to get it printing on the network or should I just cut my losses and keep it as a spare?
Any advice will be greatly appreciated,
Seth
Seth
