FS-C2526MFP
  • tcypy1961
    • 773
    FS-C2526MFP
    Black copies are extremely light; copier not calling for toner; vacuumed out chamber to black in transfer unit and copier toned up however week later same problem. Installed another toner cartridge yet copies still light . Solutions???
    Thanks!!!
    • 23010
    Re: FS-C2526MFP
    Have you done any of the modifications on this machine? Please search Gemini Modifications. =^..^=
    • JR2ALTA
      • Feb 2010
      • 2033
      Re: FS-C2526MFP
      Sorry I dont even know if you mean "copy" or "print" but many "copy" density issues can be darkened by changing around original settings from text/photo, photo, text, etc etc
      • tcypy1961
        • 773
        Re: FS-C2526MFP
        I tried google searching your suggestion and came up with everything but the copier; did add for the requested copier and saw a conversation back in 2013 yet never spoke as to what the mods were. Would just replacing the black developing unit work or be a temp repair??? Thanks!!!
        • tcypy1961
          • 773
          Re: FS-C2526MFP
          copy only; this is definitely and undertoning issue and copier does not recognize it. Thanks!!!
          • Trigger
            • Aug 2014
            • 16
            Re: FS-C2526MFP
            normally the gear which drives the toner auger down the side of the transfer unit snaps off and causes this problem.
