Kyocera KM-4050 Cassette 1 tray wont open (Copier Moved with Paper in Cassette)
  • rbarbour
    • Aug 2025
    Hi Folks,
    Cassette tray 1 will not open. When looking inside best I can, I see a half ream of paper still in the tray and the tray lift seems extended to top of tray. Is there any way to reset that tray so it can open? Evidently girls left paper in the tray before the copier was moved to the other building.
    Thanks in advance for your help,
    Rob
  • Zackuth
    • Aug 2009
    • 448
    Re: Kyocera KM-4050 Cassette 1 tray wont open (Copier Moved with Paper in Cassette)
    Try turning the machine off to open stuck trays. Discovered this by accident trying to open a drawer that the customer didn't have the guides tight against the paper and the tray stuck.
    If at first you don't succeed, redefine success
    • Tonerkiller
      • Oct 2012
      • 668
      Which drawer ? did you try 906? Depending which drawer you can take the lift motor motor off in the back
        • 23009
        You may need to remove the lift motor from the rear to get the lift plate to drop. =^..^=
        • copierwizz
          U906 will not always release the trays. Try switching off the machine and remove power cable and leave it off for 30 seconds.
          • darry1322
            • Oct 2010
            • 817
            It's been almost 4 years, hopefully they got it resolved.
            Someone else might find your tip useful though. Welcome aboard.
            • NTS_cz
              • Feb 2021
              • 3
              This helped me even in 2021, thanks. Kyocera M6030cidn, just helped me to find out where to look, just removed lift motor, it whined and cassette was unblocked.
              Thanks again
                • 23009
                Your welcome!
                  • 16416
                  So, a blackcat post from 2014 solved a problem today. Maybe we should start a permanent "thank you blackcat" thread. May save some time.
