Kyocera FS-C2126 C4600 Error code
  • A\ztech
    • Feb 2011
    • 57
    Hi Guys
    Got a FS-C2126 with a c4600 error code, I took the Laser units out and checked the operation of the Laser cleaner by hand. I'm thinking it might be in the motor and gear assy. but wanted to check and see if anybody's had this problem before I start tearing the machine down for that its in a customers office and not much room to move around.
    • 22997
    Re: Kyocera FS-C2126 C4600 Error code
    There's a bulletin on this. Essentially, the manufacturer totally redesigned the slit glass cleaner drive. The new parts do not fit on the old style laser. So you have two choices:
    1) Replace two laser assemblies with new style parts.
    2) Once every 3 months you'll need to remove the transfer belt, drums, developing units, loosen two screws securing the rear laser, and manually home out the laser slit glass cleaner.
    Personally, I selected the second choice. =^..^=
    • A\ztech
      • Feb 2011
      • 57
      Thank You Blackcat, I'll check the Bulletins again and probably do the same thing to home it out whenever it kicks up the code.
      • A\ztech
        • Feb 2011
        • 57
        Blackcat could you email me the bulletin for this problem I haven't been able to find it, Thank you in advance
        • Doug Money
          • Nov 2011
          • 41
          I have the same problem and I can't find the Bulletin either. Do you have the bulletin number or can you send me a copy of the bulletin? dougmoney@gmail.com
          Thanks.
          • copycoan
            • Sep 2012
            • 31
            Same problem, just power off the machine, disconnect the wire of laser cleaning motor from engine, power on the machine and it works, while powered on reconnect the motor and still working fine. It sounds like easy to solve by firmware mod.
