FS-C2126MFP Processing & washed out
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1885
    We have 4 or 5 of these that the Processing light is flashing & the engine is cycling, but nothing comes out. Sometimes it will be 15 minutes. Cycling power will immediately print the job. It's happening on copies & prints both. We've added expansion memory etc. I was thinking possibly bad temp/humidity sensor ?
    Also, does anyone have a fix for the washed out prints ? Shaking the DV units brings it back.
    The full updates have already been done to these units.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
  • AlbertK
    • Jul 2014
    • 90
    The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
    • tmaged
      • Oct 2008
      • 1885
      Re: FS-C2126MFP Processing & washed out
      Yeah, the 41 page update & firmware have been done.
      Hope that helps !
      -Tony
      www.dtios.com
      • AlbertK
        • Jul 2014
        • 90
        Did you get it sorted ?...
        When the machine is idling, what does it display? Processing or please wait or adding toner ?
        • tmaged
          • Oct 2008
          • 1885
          It turns out that a few of these had the spring missing that puts pressure on the feed unit pick up tires. The machine will just keep trying to pick up the paper without showing a jam.
          Hope that helps !
          -Tony
          www.dtios.com
          • Foxhound
            • Mar 2014
            • 33
            Run Dv Refresh several times and eventually you will gain density back. this model is trickle developement and if coverage causes the dv res. to run out it needs a devloper refresh. I have solved the same issue by doing this. you may need some spare toner good luck.
